79 L82 Engine code
raybee
Long Island
1981 Dark Bronze 4 Speed
Hello all, looked a decent car today.....the code on the block near the water pump read V0605ZBA......can I be confident that that is the original engine? It is a 4 speed.....Any and all thoughts are appreciated...Thanks, Ray:ohnoes
ZBA is the block code for a 49-state 350 in an 82.
As for whether or not your engine is the original engine...you will need more information than just the block code to tell.
Thanks, can this be determined by the 9 digit code underneath that block code?
Raybee: there are two stamps on the engine pad; the engine ID code which you apparently found and the VIN derivitive.
The VIN derivitive should match your VIN.
Thanks, Mike - I think i'm good - the last six digits on the engine pad match the last six on the VIN!! I think i'll make him an offer today!!
