81 cam change
  • Thread starter Thread starter Tomlin
T
Tomlin
Sorry I missed you all in the chat last night, once again I couldn't get in. I emailed Rob and tonite will send him my computer specs. Hopefully next time. NOW to the topic. Has anyone changed out the cam on an 81? I'm considering a performance cam and am interested in opinions and procedures to install. I've done a change in a old mopar years ago but never a Vette. Any help would be appreciated.
Tom
[Edited by Tomlin on 12-03-2000 at 07:37 PM]
Hi, I recently rebuilt the engine in my 81 and the main problem is getting at the cam in the first place. You have to remove the radiator and also the a/c radiator if you have it. This turned out to be more difficult than it first appeared, the cam won`t come out unless you remove them. After you have cleared the way the cam swop is straight forword and can be done with the engine in the car. I ended up removing the a/c altogether and the air pump had already been taken out by the previous owner.
When I put it back together again I refitted the radiator and had most of bits`n`pieces back on the engine but could not get the fan cowling back in place with the rdiator fitted so I had to take the radiator out again and assemble them and put the cowling and radiator back in at the same time.
I hope this is of some help to you
J.
