Antz81
I tried to start up my 81 after it had been sitting for a while (about 6-7 months i think it was) it started up but died within about 1 min and i haven't been able to get it to start since.
At first i thought it was probably just bad fuel so i drained the tank and cleared the lines. also fitted a new fuel filter while i was at it.
I put some 98RON in the tank (i know it would only need 91 but just want to be sure). cranked it over until the carb had fuel again but still no signs of life.
I've fitted a new rotor, dist cap and coil also (i had these all ready to go before the problem started)
I pulled the #1 spark plug to confirm timing was roughly right (not 180* out) and noticed it was black also checked the type NGK BP5FS. a quick look showed that this is not the NGK equivalent for the correct plug (R45TS)
Is this likely to be my only problem? or will i need to look further into this???
