qualitydude9000
New member
Hello, I have read several post to fule problems on a 82 crossfire,
The car was running fine we left for 20 days came back and the car will not start. I got it started with starting fluid, but no gas to the carbs?
The relay clicks on for 2 seconds and goes off I tried another relay I found on the firewall that matches it clicks and goes off like it should.
I have 2 wires and a ground on the top of the tank BRN/W stripe, orangish brown this wire barely has voltage is this the gauge? Is the brn/w does it have voltage?
Please walk me through the process.....How do you know if the fuel pump is out?
