Ludigdrums
I have an '81 with an '82 hood on it. It has this louvre in the front that is supposed to be for the crossfire setup, when you give it full throttle, it opens up, directing air to the air cleaner setup.
Anyhow, I have Carb setup, but the wiring for the louvre switch is in place. I was wondering if I connect it to the ignition if that would be a bad thing. This way, whenever I start the car, it will keep the louvre open until I shut the car off. I just wasn't sure if this switch would be damaged from being open a long period of time...considering that it was only to open on full throttle.
Thanks!
- Jeremy
Thanks!
- Jeremy
