The gas gauge in my 84 started giving false readings, so I removed the sending unit and placed it on the workbench. As I moved the float resistance flucated between 0 ohms and 95 ohms. I then removed the sending unit cover and cleaned the contact and windings. I received the same readings as before.
I reinstalled the unit along with a new fuel gasket and now I get no reading at the gas gauge. I disconnected the 3 prong connector at the tank and measured across pins 1 and 3 and get a reading of 2 ohms, an empty tank. The gauge was rearding reserve, 1/4 or 3/4 when the tank is at about 3/4 full before I removed the sending unit.
Could the float have gotten hung when I reinstalled it? Could the float be saturated?
Thank you
Thank you
