silverstreak84
Looking for Prom that changes the timing of shift rpm. chevy part number 1226938.
Thanks for any info.
HI there,
There is no shift point changes with a new prom. The 4L60 that is in your vehicle is actually ONLY electrically controlled for torque converter lock up.
Shift points can only be changed by line pressure at the kick down cable or the governor.
Now, that being said, accurate diagnostics involving shift points revolves around correct line pressure readings vs throttle position sensor and load on the engine itself.
Allthebest, Paul
