T
timzim
The headlight motor will not stop spinning once the headlight is in the full upright position. If I turn the head light off it returns to the down position and the motor stops like it should. Any clues ?
I was just trying to be helpful, Tyrel. As many of us know, this is a common problem and one I tackled a couple of months ago using bushings from Home Depot.tyrel said:Wow this problem is coming up a lot. It's most likely the bushings inside the headlight motor housing, try Mid America or Eckler's, $5.00 for each headlight.
Oh, now I see. I guess someone thought that they would reply to all the headlight problems and post the same suggestion repeatedly that everyone already knows anyway. Seems a little childish.
