patrickj
Active member
Hi all my 85 does not idle correctly it surges then dies I replaced the IAC with an genuine ac delco made no difference I have a question about a change I made recently.the oil pressure switch failed so I bypassed it with a toggle switch did not think it was necessary as I installed mechanical gauges.the switch runs the fuel pump.the engine is new with all new vaccum lines I checked for vaccum leaks at the intake mating surfaces etc.no vaccum leaks anywhere any ideas? Thanks
