I
I_R_DA_ONE
My 86 vette at times has a mind of it's own.....sometimes it will start and run fine but then other times ,,, the motor turns over but it will not start.... this is what I have done....I replaced the fuel pump with a new delco pump and strainer...replaced the fuel pump relay.....replaced the distributer pickup amp.... replaced the HEI coil...rotor button.. all the plug wires..and I am still having the same problem..... Is there something that I am missing that will keep the motor from running at times... Once on the interstate it just shut off and would not start.... I got it home on a rollback, then 3 days later I went out and it started up just fine... Yesterday I went to start it and it was the same old story....no start...The motor turns over good and I have spark but no fuel... What else turns the fuel off other than the distributer not turning and it picking up the pulses from the amp in the distributer???? Could this be an ECM problem??? The fuel pump relay is not being turned on when I am having this problem....
Thanks In advance
Mike R
Thanks In advance
Mike R
