SuperRob
New member
Hi guys - I'm a rookie mechanic
i was checking for error codes shorting pin A and B on the ALDL but the check engine light keeps flashing showing no error codes. The coolant fan starts would that mean the temperature coolant sensor needs to be replaced?
l started by replacing the fuel sensor relay, filter and you can hear the pump start up, there's fuel to the rail by pushing the shrader valve. I also had a new key make to ensure it had the proper resistance. What else should I do if not the coolant temperature sensor?
