metoo1012
HELP!!!! Bought a basket case and now am becoming one. Nice vet but, will not run. Starts, runs maybe 3 seconds then dies. I have checked all grounds, replaced ecm,swapped out memcal, coil, pick up coil, fuel pump and filter, spark plugs and wires, tps, est, dist. rotor and cap eliminated the dreaded VATS with bypass unit. Noid light flashes while cranking engine, timing lights flashes while cranking engine 40 psi on fuel rails, new injectors,new starter( lost the first one to abuse) timing is set as close as can be without running.
