hzl6cm
I've got an 86 that will only idle, if I try to give it any gas at all it immediately dies. Here is a little background. When I got this car the guy was doing a little paint work, a little interior work and a little mechanical work all at the same time in a small garage so it had been off of the road for a few months. I could start the car and it would idle but would not accelerate at all, if I hit the gas it would die. I could drive it as long as I juste did it at idle. He had recently installed new fuel injectors and had a bad intake vacuum leak - I thought that was what was causing the problem. I fixed the leak (after replacing all of the intake gaskets I discovered it was the cold start injector - his kid had bent the bracket so it wasn't seated properly). But the car would still only idle, as soon as I give it gas it would die. Some of the spark plug wires looked bad so I replaced them and I discovered some bad vacuum hoses so I replaced all of them. Still no change except that it now starts harder than before (cranks fine and fires off of starting fluid but doesn't run on gas for long). Further info, the check engine light is on but when I hook up my scanner (Auto-Xray) it won't communicate with the computer.
Any ideas? I thought maybe the TPS but don't know how to check it if the computer won't talk with the scanner. I thought maybe the computer was bad but would it even idle then?
Thanks.
Kevin
Thanks.
Kevin
