S
seabee 86
1986E with 200+k
Alright heres the problem. Over the winter I replaced the PCV valves with those breather caps and deleted the EGR. When I eliminated the EGR and PCV valves I also eliminated everything that they attached too. The car will crank and fire right up like it did before I touched anything, but then it sputters and dies out within 1 second. If I rev it up it'll stay running, however I feel the engines RPM's are not relevant to how much I'm depressing the throttle (it seems the engine is revving higher than it should, but not 100% sure). Also when I rev it up, I can occasionally hear a "popping" sound coming out the exhaust.
At first I thought it might have to do with the new PROM chip I got for the EGR delete. However after taking it out and trying it again I got the same results.
Any and all guess are welcome, the car is in my neighbors garage because he spends the winter in Florida. He will be back next week so I kinda need to get this done asap. Thank you all for your help!
