8
87ragtop
I have owned my 87 white convertible for only 2 weeks and know just above zero about vettes in general. Having owned a 66 Mustang convertible for the last 24 years I finally came over to the dark side
The turn signals on the car do not work. If you try and use them no inicator light comes on on the dash. The emergency flashers work fine and I have replaced the flasher itself. I have read a little on the site about dash cluster problems, mine seems to work for the most part, although you can tell that it does go alternatly bright and dim just a little. Not sure if the two are related to some sort of ground problem.
Anybody else ever had this problem?
