greetings all,
well, as i suspected...rain. oh well however, this gives me another chance to ask another question about rear bearing / hub assembly in my 88. i have looked at he helms manual and it is not all that clear. so, i will asked here to those whom have done this already.
1. i raise the car up on stands and remove the wheels.
2. remove the brakes/calipers.
3. remove the rotor
i have read thread after thread about how next to proceed.
1. do i have to take loose a rear "tie rod" and for what purpose?
2. i realize that i have to remove the u-joint strap to drop the wheel end of
the half shaft. (i will be removing the entire half shaft to do all except the
main drive shaft u-joints.)
***i have concerns as to the speed sensor attached at the wheels. i have also noticed that there are some "teeth" on at near the rear spindle that the speed sensor has something to do with.
1. are these "teeth" attached to or part of the rear spindle?
2. do i have to "fool" with the speed sensor or these "teeth" and in what
way?
i have a helms manual and even my 81 helms left a lot to be desired in diagrams or instruction and i have found some of their directions to have been omitted or wrong as pertaining to my 81.
1. do you recommend i put loc-tite on all the threads i encounter during
reassembly?
........................................thanks again!
ps, i probably would not ask these questions if i had been under the car yet but, as of yet, i haven't!
3. remove the rotor
way?
reassembly?
