1989 Covette 350 tuneport; starts and then quits. Have replaced: ignition coil, cap, rotor,wires,dist pick up,dist module,mass air flow, throttle position sensor,esc module,coolant temp sensor,fuel pump, fuel pump relay, fuel pump regulator, fuel pump sock, fuel filter, ecm. Throttle body and plannum have been cleaned, vacuum hoses fine, fuel injectors pulse. There is something that regulates the timing, dst(?), and when that is disconnected it runs but has no throttle response. Other than that no matter what is done it starts up and then stumbles and quits. Any help would be greatly appreciated.
**Sorry, I posted here in error-should have been in C4
