'90 Vette has a Whistling Noise...
XtremeVette
Murfreesboro, TN
2002 C5 Coupe
90 VETTEÕS got a whistling noise
I have checked all the hoses and belts..donÕt see anything wrong there.....How do you know if its just a loud alternator? This is the type of noise its producing....sorta a whistling, wining noise....the alternator was replaced last year with an aftermarket from the autoparts store...I have no problems resulting of this noise....just sounds weird....is this just normal?
thanks
jeff
Re: 90 VETTEÕS ...
VETTEÕS ?? :confused
Did you intend that to read as such, or shall I edit it for you?
By the way, alternator bearings are notorious for failing early sometimes due to the increased underhood temperatures in the Corvette. ;)
thanks...please ken
yeh...iam on a mac and the quotes or apostrophies do that.....strange...lol
just one of them things..lol
jeff
ps...thanks...i will try the screwdriver test on the alternator and see what is what....damn man....she's only like a year old...lol
I have a friend who says he never leaves town without a spare alternator. :L
I've had 'em go out in less than a year. NAPA will give you another, but what a PITA to change it every year or so. There is an, however, an alternative [size=-5](which I should look into ;))[/size]:
The "Iceberg" Alternator™
The "Iceberg" Alternator™ is your best defense against heat related failure of the Delco-Remy CS-130 type alternator. The "Iceberg" Alternator™ is only built or supplied by authorized re-sellers using only top quality components. To truly be an "Iceberg" Alternator™ it must also use the Patented "Iceberg"™ finned rear housing for better cooling of the alternator's internal components. Click here to check out the "Iceberg Alternator™" conversion kits.
_ken :v
