I don't Agree!! There are several things that can make L98 hard to start Warm,Not just the Injectors!!
Weak Coil,Ignition Module Going South,Bad Distributer Cap,Bad Rotor,Bad Plug Wires,Spark Plugs,Wide or Narrow Gapped Plugs,Fuel Pump,Fuel Filter,Fuel Pressure Regulator,O2 Senors,Small piece of carbon in EGR,Temperature Senors,Vacuum Leaks,Low Compression and others!!Plus some of the above can also cause Tachometer problems!!
Get a FSM and trouble shoot by the book,without it a inexperienced mechanic will be just P*ss'n in the wind!!
Having similar issues with a friends 89, I have been "living" the chase!!! I spoke with GMJunkie last saturday about what I had done so far, and he advised a few more steps. So, here is what I did and where I'm at:
Original Issue: the car "dies" like someone turned off the ignition upon acceleration from a stop, or "stumbles" at speed (wants to dies but recovers).
Replaced Ignition Control Module. Replaced rotor and cap. Replaced coil.
Thought it was solved but, when hot (220 degrees) stumbled in city starts.
Took to shop to replace fuel filter & fuel pump (need lift for filter). Car "stumbled" all the way to the shop at each stop light. As long as I kept RPMs up, and 'feathered' the accellerator to do slow start, I could get to next light. (this is before fuel pump and filter).
After fuel pump and filter, cal would not start at all!!!! Lots of crank but no connection. Good fuel pressure, and there was spark. Would not start. Went for lunch, came back, she started. Would idle for a few seconds, then cut out. Had the computer plugged in and saw no codes or issues. Correct voltage readings everywhere.
Replaced (I think it's called) Throttle Control Module. No change.
Stumped! Towed it to dealer. They have diagnosed it as bad ECM. Also, there are 2 very bad injectors with the rest being "marginal". (BTW: car idles smooth when she is running).
They have replaced the ECM but I'm reluctant to drive her home to do the injectors myself for fear that the bad injectors will blow the ECM again. (Dealer wants a fortune to do the injectors, like $200 each plus labor).
Sorry for the long message but the devils always in the details. (I'm living the list that GMJunkie stated!)
So, any thoughts or comments about driving her 40 miles before doing the injectors? Or other thoughts?
Thanks. Hal
