ochenee
New member
Hello all, I have a 1992 vette that i think the vats system is failing, i would like to know how to remove it entirely if possable, problem is it starts, runs fine,about 5/10 min the security light starts flashing, along with a sys flashing in the speedo, then the sevice asr light comes on, all the wile it continues to run fine no problems, until i shut it off, then it wont start back up, sometimes it starts and dies, security light flashes and so on, if i pump the gas pedal i can keep it running, but when i stop pumping the gas, it dies, when it isnt starting it still cranks over fine, ive bought a new pass key, no luck, had the ccm tested and reprogramed, no luck, had it in a shop for months, they couldnt figure it out, sometimes i can diconnect the battery for a wile, reconnect it and it will fir right up and run fine, then the same thing happends,(flashing security light and so on) then i shut it off, and again, cranks fine but wont start, whats up with that, does anyone know out there? All the grounds have been checked out ass well, I think the vats is cutting off the fuel, any help on this would be greatly appreciated! Thanks. Mark
