9
94Roadster
Whether the car is warm or cold it turns over perfectly, but it doesn't start right away like it use too. It cranks over rapidly, and after about 5 - 10 seconds starts up. If I shut it off, and it starts right away. I did this about 10 times in a row and it started every time. Start it let it stablize and shut it off and then turn it right back on. So then I let it sit for 5 minutes and it cranked and cranked and then fired. I shut it off and it started right up again. So far this year, I've done this to the car. Since I'm in Minnesota and store the car all winter. I had all the fluids changed, oil, coolant, brakes, transmission, rearend. The opti-spark (all rusted inside) and water pump (bearing was shot) all new plugs and wires. What should I try next? I don't have a fuel presure gauge. Is it hard to replace the fuel presure regulator? Are they expensive? Should I try that next? :duh
