94conv.
My 94 just started idling real low then drops down more and dies within a few second of starting. I noticed this Sunday after a five hour drive. The idle would drop but not die before this occasionally since I started driving for the season a few weeks ago. I cleaned the IAC and it ran fine after that. I took it out for about 20 minutes after that and when I got back it started and ran fine and it started and ran fine yesteday evening but when I got back after going up the road about 10 or 15 miles and back, it did it again, which makes me think its doing it or doing it worse when it gets warmed up or hot. Not sure if its the IAC acting up where maybe it just cooled down after I cleaned it but there was a big difference after the cleaning. I cleaned the EGR about two years ago when the idle got rough but it didnt make much difference but eventually straightened itself out after I drove it more often with better gas. What does the Map sensor do? also what affect would the tps have on start up and whats the possibility of just having a bad IAC? Id like to get a good starting point before I start throwing parts at it. Thanks for any help
