M
mortenals
Hi.
I have two identical 1996 LT1's with about 85 K miles. One of them wont start. It used to start imediately and run perfectly but after the winter I havent been able to start it and tried almost everything.
The fuel pump starts and runs for a few seconds. The engine cranks fine but there are absolutely NO sparks. I believe I can smell gasoline in the exhaust pipes after cranking but I am not sure. I use Dyno-Scan from Auterra for OBDII-testing but it does not give any errors (present or historical).
Here is the short version of a long story:
New (reman.) computer,
8 spark plugs and wires,
New Ignition Control Module,
New harness to the Opti,
8 new injectors.
Today I wanted to change the Opti with a new one that I purchased, but it turned out that they send the old version that is not vented ad .
And the old one looked perfect and was absolutely dry inside, so I just put it back on.
I suspected the computer so I tested it in my other 96 LT1 (after switching the box (KS module) in the bottom of the computer) and it starts up immediately.
According to the Shop Manual the resistance between terminal D on the Opti connector and ground should be less than 5 Ohms but it is 11-14 Ohms. Both wires between the computer and the Opti connector (Opti-A to pin2. connector2 and Opti-D to pin3.connector2) measure about 1.1 Ohms. Do I have a Grounding-problem?
8 new injectors.
- Is there any way to verify the signals coming to and from the Opti?
- Is there a simple way of testing my scan tool by producing a DTC?
- Is there a way to use blinking lamps to indicate errors as on the older C4's?
- The manual talks about reprogramming a replacement computer. Could that be the problem if the car has been starting running a short while after the replacement?
