sandmanjws
New member
My a/c is blowing cold air on the drivers side and really hot air out of the passenger side outlet. This all started after the battery was disconnected for service. I went thru the codes and cleared them all and freon level is good. The codes that keep showing back up after the clearing procedure are BO365, BO367, AND BO446. During the code clearing process you can hear activity taking place under the dash but as soon as the key is back in the switch and the vehicle is restarted the codes and hot air is back. I tried the reset procedure 4 times and no luck, still hot air. Please, help.
Thanks, Jimmy
Thanks, Jimmy
