- Thread starter
- #21
dshanks
TJay said:Check the other side first, and can you post a picture of what you have apart. I have a lot of pictures, just not sure which ones to post for you to see a complete install or stages of it where you are now.
Basically, I have the entire left side apart, painted, and ready to put back on. the right side is untouched, because I wanted a reference (just in case).
I slid the left cross shaft over the frame studs for the right cross shafts (without removing the right), resting the left cross shaft on top of the right cross shafts so that I could try to see the difference in the two without taking the right cross shaft off. I couldnt see any difference between the two. is there a measurement that I should take that would indicate which direction is forward on those cross shafts?
