Randys88Vette
Ok guys.....here's a tricky one for you. My A/C has been working just fine. The other day, it switched from blowing nice, ice cold air, to sweltering hot air. The A/C systems is full (had that checked by pro's), and there are no freon leaks in the system. If I make a sharp left hand turn the A/C goes back cold. It will run fine for a few minutes, then turn back into hot again. If I make a right hand turn when the A/C is working, it immediately goes full blast HOT. When the A/C is working, it comes out the dash vents. When the heat kicks in, it comes out the dash and floor vents. I tested the divertor/blend door opening and closing, with the ignition on after running the car for a few minutes to get vacuum. I can hear the door cycle for hot (heat) and cold (A/C) just fine. I have read all about the possible vacuum leaks but have no idea where to start looking. I have both the service manual and a haynes, which dont help me much. The "Baby" is an '88 with electronic controls. And, I particularly dont like the idea of having to tear open the evap housing to check it all out. This is the first I have had this problem and in these forums, someone always has the answers. I need some help here guys, and hope i can return the favor some day. Thanks....
Sure hope I can help someone else sometime. Thanks everyone!!
