Stumbo
I've read on several forums that high hp cars can't hook up on the street (or even on the freeway when changing gears) very well so the diff. gear ratio is lowered to solve this problem. One very high hp car was runnin' 2.73 gears otherwise he couldn't really use 1st or 2nd w/o burning rubber.
I'd like to see something about this topic
Also, when changing tires widths and sizes, which ones will not affect the abs or traction control?
Also, what is would take to install the C6 brakes on a C5 (rim size and anything else)?
Also, how about oil, trans and diff coolers? Under what conditions are they needed/optimized?
How about A&A Corvettes frame and rail savers?
Installing an automatic antenna in a Z06?
Installing/adjusting/benefits of coil overs?
Installing an STS rear mounted turbo? Turbo boost and compression of an engine?
The most important one of all: which mod will improve a Z06 as opposed to a standard C5?
How about spark plugs wires, throttle bodies, etc and a dyno before and after installation?
A baseline of the stock C5 should be done and then compare after a mod is done to "prove" that an improvement was made (or not). Anything less than that is hearsay.
Some of these have probably been covered on the site but I'll throw them out anyway, just in case.
