a DIFFERENT cheap fix for cracked interior pieces
dshanks
KCMO
1971 4spd coupe - Charcoal Gray
I noticed in the other recent thread on this topic that his dash reskin project started with a very small crack.
I thought Id share with you guys how I addressed this problem.
When I started my restoration, I knew I wanted to restore it to original, but unfortunately there were damaged areas all over the interior. And I was too broke to replace major interior parts. Fortunately they were small enough to repair.
These interior pieces are foam wrapped in vinyl, whick cracks very easily. I discovered a glue that repairs this type of material very easily.
I'm a graphic artist, so I am a little crafty, but I think anyone could do this.
I started with an expensive (but worth it) glue called PascoFix. Its used in conjunction with PascoFill. Pascofix is similar to superglue, but comes in a larger bottle, maybe 2-3oz. and is MUCH stronger. PascoFill is a granular filler, resembling white sand. It comes in the same sized bottle...
Heres a link:
http://www.pascofix.com/
Anyway, Ill give examples of how I fixed certain common problems.
Ill start with the dash.
My dash was ok, with one large crack near the drivers side A-pillar that went almost from front to back.
I poured the PascoFill in the crackand leveled it off. then I lightly added Pascofix as needed. When the two touch, they bond/dry instantly making a rock hard repair. Try not to get too much excess because the dash material is weaker than the PascoFix, so material removal takes a LIGHT and exact touch. I sanded the crack smooth.
Then I turned the dash over, and sparingly allowed the PascoFix to soak into the foam behind the speaker grill that had no cracks. this instantly turns the speaker grills from the most fragile part on your car to the hardest part of the dash. Its amazing and will never crack, ever. Anyway, the one that was cracked, I "welded" together with PascoFix and PascoFill. I LIGHTLY sanded the grill smooth
I refinished the dash with vinyl paint.
The final repair does not have the texture that the original does, but If you can keep the repair small enough, it isnt noticable. My dash looks practically perfect...
The door panels can be treated the same way. Use it to fill small holes in the vinyl and cover with vinyl paint.
The mid-console area had cracks toward the front corners, and upon closer inspection, I found out that it was broken into pieces and was held together by the vinyl itself.
I clamped the piece together. I used the PascoFill generously to fill in the cracks in the fiberglass, pooling it up real nice in the corners like a weld bead. then add the PascoFix and it welds the pieces back together instantly. once done, these welds are stronger than the fiberglass itself.
I also used it to fill the forward corners of the piece and rebuild the material there as they were practically busted to pieces. Its too hard to replicate the stitching there, so kiss that goodbye unless youre an ace with this stuff...
There were areas that I didnt want to sand, or needed just a little bit more help than the Pasco can offer.
for this I bought a vinyl repair kit from eBay. Throw away the directions.
Use the black (or whatever color your pieces are) to sculpt, fill, or build wherever you need it. Then use a heat gun to dry the stuff. It can be LIGHTLY sanded if need be, but this is discouraged.
All pieces are painted with vinyl paint to match.
i also used PascoFix to reattach the thread tubes (?) that are attached to the rear interior quarter panels that bolt to the metal painted strip in the door jamb. Sorry for the stupid terminology...
If you were sitting in my interior, you would be hard pressed to find any repairs in the car but the ones that were large scale like the dash crack. I bet I repaired 150 small cracks and nicks total. Even the dash crack is very hard to see from the drivers seat, and impossible from the passenger seat or outside the car through the windshield. All minor repairs are invisible to the point to where I cant even find them to show people where they were.
If you try it, good luck, all it takes time and patience, thats it.
Derrick
Thanks. I'll bet plenty of folks will appreciate your post. :upthumbs
Thanks for the tips, never heard of the adhesive you mentioned before. I'll check into it, sounds like you're very happy with it.
Bill
Bill
Yes, theres no telling what kinds of uses this product has. It saved me a ton of money. the bad thing is that the tip gets crusty and clogged. Im sure better care would have cured that. Oh well...
Do you have any before & after pictures to post?
Hey Derek, whats going on?
Hows our friend in Phoenix?? haha. Hope everything went well for you, Ive been saving money to do my thing. Been dating a lawyer so that may help my cause...
Back to your question,
I can go take some finished pics. the resto isnt done yet so I havent taken alot yet.
Unfortunately I dont have any before pics of the interior. Im now kickin my self in the a$$ for not taking many before pics.
Hows your vette coming along? get that front end tow damage taken care of?
Derrick
........ My dash was ok, with one large crack near the drivers side A-pillar that went almost from front to back.
I poured the PascoFill in the crackand leveled it off. then I lightly added Pascofix as needed. .......If you try it, good luck, all it takes time and patience, thats it...
Derrick,
Thanks for the info.
I just visited pascofix.com and ordered the "Pasco Fix, Fill & Accelerator Combo Special."
This morning I removed and replaced my speedo and tach... my lower front dash has a number of cracks. I'm gonna use the pasco fix to hopefully mend these back together again... I look forward to using it.
Thanks again.
:w
Ralph
WOW!
Derrick,
I just tried the Pasco.
I was actually a little skeptical - I thought it would be like super glue, but It's really an incredible product! The Pasco Fill powder mixed with the Pasco Fix works in seconds and it is indeed stronger than the fiberglass.
I was able to fix my lower dash and the steering column cover in about 45 minutes.
Thanks again for the great tip.
Ralph :w
Derrick,
Ralph :w
Glad it worked for you!
Another tip I forgot, dont let the vapors get in your eyes...OUCH!
