AnthonyMicheal
New member
- Joined
- Apr 29, 2013
- Messages
- 2
- Location
- Veneta,oregon
- Corvette
- 86 bright red Corvette w/ 400 cid w/TPI new rebuil
Hi Guys, New here but looking for some help w/ new rebuild...
I just acquired a 86 Vette that needed some help and after finding a bad rod bearing on # 3 cyl, I decided to do a complete rebuild on the engine. After discovering the engine was not the orig. but a 400 cid, I continued the rebuild and started the installation
Anyway, did I mention? The engine was removed by someone else. After a lengthy process of puzzling the accessories back together the best I could to factory there are a few things I can't seem to figure out quite possibly because the parts are not there
ad I consider myself very resourceful in most situations but I can't seem to find information on the routing of the A.I.R. air pump hoses and a correct routing of the associated vacume. There is also a connector under the plenum to the left of the egr I'm assuming, that I can not find the wire for. Thanks to the info I got here a few minutes ago, I did get the routing for the egr vacume.
Can you guys direct me to the best place for the info I need for the Air pump? Diagrams, schematics whatever? Hopefully, you could also read between the lines that I bought this car with very humble means which also means I ve exhausted resources for being able to afford the luxury of obtaining the more informative reading material to finish.
Can someone help me out so I can start enjoying my investment instead of regretting a new liability? Please!
Thanks for reading this post... Anthony
