C
CAJUN C4
How would you like approx. 5 H.P. from a Plug Change.Check out the "Spark Plug Dyno Shoot Out".
Fire Power - Street Thunder
Plug test results look more comprehensive than the ones for the Renegade intake and you bought one of those; sight unseenSave your money it is a scam.
Plug test results look more comprehensive than the ones for the Renegade intake and you bought one of those; sight unseen![]()
I have won races on lessThats .002 seconds faster in the 1/4......WEEEEEEE!!!
Isn't TPIS the same company who devloped the air foil? Would of prefer this spark plug test completed on a stock engine on a dyno and include the stock AC Delco plug as the baseline plug. I'm sure there are some diffrences based on plug design, but 5 HP on a 385 HP engine is around 1%. I've run stock AC Delcos and AC Rapidfires on L98s, and prefer the Rapidfires because of the coating that prevents rust. The amount of driving my vette sees, they will not be replaced for over a decade.
plug test results look more comprehensive than the ones for the renegade intake and you bought one of those; sight unseen![]()
Problem with most " instant HP ' adders is that while they may be based on sound scientific / engineering principles whether you will see any gains remains debatableAir foil will make a difference on some engines.
