74bigblock said:
Back on topic... lets ask some important questions:
1) How often do you exceed 120 MPH?
This is a typical point raised by those defending the practice of going with non-performance tires and suggests a lack of understanding as to tire construction techniques to obtain an H or better speed rating.
It's not about driving all day long at 120 on the autobahn, it's about strength as it relates to performacne and safety. Currently we have a choice between the barest of minimal standards (S or T rated, B temp ) and a step up to an H or even V tire with A temp. And I might add it's at least been proposed and discussed by DOT to up the standard and I'm not so sure these entry level tires will cut it.
SO I ask why would anybody put such tires on any car, let alone a Corvette, operated at 75+ mph? Even plenty of everyday average cars include better tires than this - let alone a sophisticated high end GT like a Corvette.
People seem to see value in safety items like shoulder harnesses, collapsible steering columns, crumple zones, air bags and ABS, or in performance items like exhausts, heads, carbs, EFI, etc... yet when it comes to tires even when given a choice for a mere few dollars more... people seem content with the absolute lowest entry level, weakest option available with the least safety margin...
Ever seen what happens to fiberglass when chunks of weaker rubber disintegrate at speed?
In addition to the single most important PERFORMANCE aspect of a sports car, if one doesn't believe a tire is one of the most important SAFETY equipment items on any car - one apparently completely missed what happened to Ford, Firestone and numerous victims on the roads a few years back.
For about a 15% increase in manufacturing cost - an H or better rated tire w/ 'A' temp gives you a stronger tire, with better heat handling characteristics, and additioanl layers of nylon cappings not present in the entry level basic S or T rated fare. A stronger tire in turn gives better handling performance which should be intuitive. And a tire with a lower UTQG typically (UTQG can't be compared easily across brands but only generally) is a softer compound that gives better dry adhesion.
74bigblock said:
2) How often do you take hair pin turns at 50 MPH?
In an independent rear suspension, 4 wheel disc brake sports car w/ low CG and excellent fore/aft weight distribution w/ gobs of torque in every stock base model - the operative question is: How often does one pass up such an opportunity?
74bigblock said:
In my book, 'cheap' doesn't really enter into the picture for tires. Be cheap on air filters or paint jobs. But tires? With all due respect - NEVER. The H rated 225s potentially offer some savings if that helps while still providing a good minimal degree of strength, safety and performance.
74bigblock said:
What looks good? What hooks up decent? What works in all weather best?
I seriously doubt any S or T rated cosmetic performer is in the same league as a tire like the V rated options w/ UTQG in the 300s and A temp. They only offer cosmetic performance.
Clearly a summer tire is inappropriate in all weather - the single tire that does it all would be an 'all season performance tire'.
74bigblock said:
I can tell you I love my Firestones. They hook great... better than great.... maybe its my car i dunno, but look at my sig... and look at my other car in my signature... my vette still gets off the line significantly better. These tires are fantastic in the rain too. Not an Iota of sidesteping in the rain (yes I have driven my vette in the rain two or three times... got caught in it... what can ya do... it's Chicago!).
I too had similar cosmetic tires until I started learning about performance and tire construction...
What if these tires were run at a local amateur autoX in a street tire class? Or what if they were inadvertently underinflated and cruised in the desert southwest at speed in the summer with a fully loaded up car perhaps w/ a BB?
Everyone has a choice since US DOT tire standards still remain low - I just like to see folks come to informed fact based opinions, take the time to learn something about tires as well as handling and performance and safety and construction as it relates to tires. I find it interesting that so many seem so well informed about engines and transmissions and heads and carbs and oil and on and on yet when it comes to tires... well...
