abs wiring plug
wholmes98
McKinney,tx
I need abs module wiring plug that will fit a 98 abs module with code M. Are there sources that will rebuild plugs such as this. thanks.
Ok. Tell us which plug this is...
The one on the end of the ABS wiring harness?
Or the one in the side of the ABS module?
You didn't answer the question.
Is the plug you need on the end of some wires or is it in some device, either the pump motor or the ABS controller?
If that part is available separately, you'll only find it from a GM dealer, or more likely–considering the age of the car–a salvage yard.
What is the problem with the connector on the end of the ABS harness?
