R
ruby9340th
After replacing my battery the other day, I notice the light on my electronic ac unit was flashing....checked manual and saw that this indicates some sort of electrical problem with ac unit. I ran the hvac system diagnostic method (holding up and down fan buttons down at the same time) and then going thru parameters till I found only one error code, which was an 02 (temp door motor circuit fault). Is this a simple fix or not? I tried pulling the fuses listed in manual to reset system, but want to make sure I am pulling the right ones, I saw another thread which stated pulling the fuse #27 while the system was running, but that was for a C5, I don't imagine a C4 is the same. Thanks;help
