- Moderator
- #21
Will the Renegade intake help my 82 collector edition an in what way. like your vette by the way. also may add Borla exhaust. ThanksWelcome to the
The crossfire gets a bad rap because people don't know how to work on them AND they don't know why certain things were engineered the way they were.
The cars themselves are good- it's the intake, fuel delivery system, ECM, cam, and heads that aren't performance oriented. All that can be addressed though. Most people just don't take the time to learn about them and understand them.
You can certainly replace the OE engine with a 383, side exhaust, and go carbed. Lots of people have done that. There are kits for the 700R4's lock-up that make it either manual with a switch or use a stand-alone harness with a speed sensor and brake switch.
Lots of options... you can re-PIN the harness for port fuel injection, add in the remaining wires for a port harness, and run with an LT1, TPI, etc. Heck- you could even upgrade to an LS1 and retain a significant amount of the EFI harness in place if you are willing to study which wires you need to keep and make a list of which ones you need to add when you re-PIN it.
You have LOTS of choices these days- some choices cost LOTS more $$$ than others.![]()
Either way... welcome to the CAC!
There is a great post in the crossfire section on the CAC on how to set the balance by GeekinaVette
Sent from my iPhone using Tapatalk[/QUO
Thanks Kane! Nailed it. Runs great, idles like new and great off the line, no hesitations and breaks them loose!! Very happy!!!!
Great knowledge!
Bobby
