I'd drive with a little more ease if I knew I had a working emergency brake.
I've tightened the adjusting nuts up to the max position and now get just a slight braking when pulling the e-brake. My Haynes manual shows an access hole in the rotor to adjust the e-brake shoes. I don't have such a feature on my '69.
I have a spacer that I can place between the adj nuts and the bracket at the "Y" to give me more adjustment.
Is this OK to try or would it be too "Bubba"?
Anybody have a similar problem and a fix?
