LannyL81
- Joined
- Jul 20, 2002
- Messages
- 653
- Location
- Oro Valley, AZ USA
- Corvette
- 81 White/Cinnabar, 96 CE LT4 sil/blk
Still working on the assembly of my L81 ('81) 350 engine. I am having a problem getting the aftermarket parts to fit with each other.
Latest one is that I put a true roller timing chain on and had to get a slightly taller timing cover to clear the timing set. But now the new aftermarket water pump I got hits the timing cover.
I can not be the only person to ever have done this...so there has to be someone out there that knows how to get around this.
Are there spacers for the water pump to bring it off the block aother 1/8"?
Then I would need spacers between the balancer and the three pulleys in order to keep the pulleys aligned with the two off the water pump...is this ever going to end?
Thanks,
LannyL81
Tucson, AZ
Thanks,
LannyL81
Tucson, AZ
