AKRAY4PLAY
- Joined
- Oct 14, 2001
- Messages
- 584
- Location
- Wasilla, Alaska, U.S.A.
- Corvette
- '77 L-82, black on black. Full mod 406 small block
Stallion,
engine horse power is not effected by gearing. gearing effects how the power is applied to the ground. if you are running a tall gear like a 3.08:1, the engine is loaded more in the lower rpm range. if you have a deep gear like 4.88:1, then the loading is moved up in the rpm range. what Bossvette was trying to explain is the mechanical advantage of a deeper gear. say you have a 500 pound block and a two foot pry bar. it will take a lot of force to move the block. but if you increase the length of the pry bar to four feet, the effort is cut down by roughly half. with the ease of movement of the longer bar, you pay the penalty of half the distence of movement. basically lower gear ratios will get thing rolling quickly with low hp figures, but you pay the penalty of how fast you can go because rpms are gained at an increased rate. the key to drag racing is getting the lowest gear you can without hitting your rpm limit before the end of the track. that way you will get the most mechanical advantage out of the power you make and not waste it on over reving or over loading. the whole package determines performance. sorry if i confused you any more, Brian.
