Idaho Slim
- Joined
- Jul 2, 2003
- Messages
- 185
- Location
- Archer, Idaho
- Corvette
- 1996 LT1- Blk/Blk. 1996 LT4 - White/Blk
Took a long trip to Reno in April on old worn out tires, no vibration even at speeds I should not publish. :nono Got new tires, Nitto NT555's and on the rear put 315x35x17's on 11x17 ZR1 Sawblades. Developed a vibration that starts to be noticeable at 45 mph and worsens at higher speeds. Re-balanced all tires, one rear was off 3/4 oz. Seemed to be better, but still there. Took it to my Corvette mechanic at the dealership. Checked out a lot of items; alignment, u-joints, even torque converter bolts and engine pulleys found everything tight. He thinks "maybe" in the tranny as it is most noticeable in drive and OD. I plan on re-building the tranny anyways in the future for drag racing, but the vibration was improved after the rear re-balance of the tire. So yesterday had the drivers side inner tie-rod replaced as we try to find this issue, it was a tad loose. Re-aligned after and now the Vib is worse. The align shows my camber is off .3 to .4 on both fronts, is this the culprit? Did not have the bushings but wanted to inquire if this is worth the expense and could be the issue? This is maddening mad Any ideas ??????
