Question: Aggravating Wind Noise
Ron Furgerson
New member
Fairfax, VA
2002 Dark Red Coupe
Guys -- My 2002 hardtop C5 has aggravating wind noise on the passenger side. I suspect weather stripping as the door and window seem to align perfectly. When I compare the driver's side weather stripping with the passenger side I can see a slight indentation about 2 inches long on the passenger side at the top corner of the stripping where the stripping meets the top of the rear edge of the window. There is no such indentation similarly located on the driver's side. Also, I notice that when the door closes with the window in the full up position, the window barely pushes against the weather stripping thus making a seal but not a tight one. I realize this seems a minor irritation but it is one that just diminishes my Vette enjoyment. Any suggestions for a fix or do I just gotta live with it? :confused Thanks for any advice.
Best Vette Yet
Salt Lake City
2003 Medium Spiral Grey
I had the same issues on my 2003. The Dealership adjusted my door so that it closed a little tighter on the window. The top door hinge was moved inwards towards the car.This was done with good results and did not have a visible effect on the lines of the vette at all. There is also a little lip on the top of the roor frame where the window closed under. Just bend this in "A LITTLE" it holds the glass tighter iin place. Hope this helps.
Ron Furgerson
New member
Fairfax, VA
2002 Dark Red Coupe
BVY -- Thanks for the quick response. I'll give it a try and see what happens. I did not think of that as a possible fix as the lines are so perfect now. I was thinking I would have to do something to the weather stripping. Incidentally, by-the-by, I was looking for a Vette like your 50th Anniv edition to match my '78 25th Anniv. edition, but no luck in finding one. I particularly like your Med. Spiral Gray color. That is so cool. Thanks again for the help
Missoura Ozarks
2012 💯 4LT GS Roadster
Window tip in/out adjustments work well also...
gmjunkie
Old Fort NC/Vero Beach FL
03 Z-51,78 L82 Coupe
Thanks for that tip. I'm supposin' that the tip in/'out adjustment would need to be made by the dealership or an auto-body shop. Is that correct?
Naw,If Shooter can do it you can!!:thumb
