81 MAKO
- Joined
- Apr 16, 2003
- Messages
- 31
- Location
- Manteca, Ca.
- Corvette
- 2010 Grand Sport 6-spd manual~ 2001 cpe auto trans
Frank, I mistakenly sent my first reply back on "pm" msg to you and I wanted to reply on the forum so other 4-spd owners could have info. You mentioned your trans. shaft leaking lube, when replacing the rear oil seal, you may want to think about the extension Brass-Bushing that sits on the mainshaft in front of seal. When this bushing wear out, its will cause and produce some vibration to rear; when the bushing is worn out, it will keep destroying new seals and leakages will start. This Bushing is a sleeve type item which helps the mainshaft run true. A real transmission mechanic with the knowledge and tool for removing and installing should handle this project. Simple dropping front driveshaft and yoke to trans. and checking the play in rear of mainshaft might help. Make sure your manual trans. is full of gear lube; its got a lower drain plug and upper to refill, if its been that long since changed. As one vette owner said there are alot of moving parts that could add in a factor here...good luck on your mission and please let us know when you find it. LOBO out!!
