K
keefyboy
Alarm install - It's going better now!
I'm stuck. (hey! first post!
I'm doing an install on a 1993 auto. Remote start, yada yada.
The problem I have is I *don't* know which one is the VATS module, and I can't figure out what to do to get the accessories to come on from the alarm. Can the VATS just be removed entirely, and just send 12v to the ECM or something?
The alarm is supposed to supply 12v so that the AC, etc. turns on when the remote start cranks up, and I've tried giving 12v to what I thought was the ignition-switched 12v feed, no dice.
Also, which wires do I splice into for the remote start? Unfortunately, I lost my job a while ago (going back into the Air Force, hoo-rah), so I can't justify spending ~$100 for a shop manual just to use this once. I've been able to figure out everything else without one so far, but this alarm installation is kicking my tail.
I found a step-by-step for a 4th gen Camaro, wish there was a C4 guide!
I've located a bunch of 12-ish gauge wires running to/from a mechanical switch on the steering column, from there I've gotten to the starter relay (yellow in, purple out), but I don't understand the relay next to it, it switches between a red and brown + to a blue - wire.
Anyone know what the module behind the radio headunit is? I figured out that the one under it is the airbag computer form the yellow-sheathed wired going to it, but I have no idea about the other one.
Thanks all!
Thanks all!
community Keith. :cool
But I do mean BRIEFLY, you shouldn't have to turn it over alot, as my car starts almost instantly with the key, this should be the same.
