- Thread starter
- #21
J
jpanek
You said "voltmeter" and didn't specify units on your 0.02 measurement - just to check the obvious, that voltmeter was set to amps (with leads in the correct spot for the meter) and your parasitic draw is then 20 milliamps, right? That is my parasitic draw as well.
A dead battery will kill an alternator (after starting with a jump or trickle charge enough to crank). Running at full charge level for a long time to resurrect a dead battery causes them to overheat. Make sure your batt is at 12.6 volts (fully charged) without a surface charge before you put it in, and get a non-buzzing alternator.
Another thought for you is to look at any ground straps between the engine and frame.
