G
golfsnc
1991 Convertable L98 engine.
I only drive my Vette About once every other week. Last week I drove around the city and noticed my volts rather low, I turned off the a/c and radio and Volts picked up right around 12. I figured it was just having a rough day in the hot sun. I headed home and parked it.
Today I try to start it and the battery is drained. I jumped the car and it started fine and remained running when I disconnected the jumper cables. But the volts went down to around 8ish when I disconnected the jumper cables and reving the engine only slightly increases the volts. After a couple of minuites of running the car I turned it off and tried to restart with no luck. I wasn't sure if I should leave it running to try to charge up the battery or if it would be extra work on the alternator. I sounds like an alternator to me, but I'm really not knowledgable with cars. Any help would be greatly appreciated.
I'm guessing its the Alternator but really have no idea.
I called chevy and a local garrage for estimates of alternator replacement and I was given $420. from chevy and $350.00 from local garage.
Do you think the car will make it if I try to drive it to get it fixed...10 miles 15 minutes?
Does anyone know of a place to get it fixed in Washington DC or Northern VA?
Thanks for any advice you can provide.
