norwegianvette
Hi. When driving the cluster went crazy and all instruments did show abnormal values. I pulled over and the car died. A under the bonnet check and the alternator was burning hot. I let the car cool down for 3 hours and it fored up so i could drive it home and everything worked normal. Today i decided to start looking for the problem and guess i need to replace the alternator but when i tried to fire it up ir only clicks on the starter even with the booster hooked to the battery. Also, when i switch the ignition on the tach goes to 2000 rpm and stays there. Any good ideas out there, might be someone had the same issue before and can point me in the right direction.
thanks,
Steve
thanks,
Steve
