Paul Higg
Look what I have done to this car!
Tuesday, January 29, 2008
Bought 1994 Corvette with 84+ on the clock.
Installed or replaced:
FSM
Sony stereo CD and new front speakers.
New lower front spoiler
PKE
Two new keys.
Lug wrench
Garage floor wheel stop
Floor mats
Driver’s headlight
Cigarette lighter.
Replaced ALL fuses on passenger door side, found many corroded
Wiper blades.
Radiator cap.
Clear plastic sill protectors.
Bilstein shocks
Lower ball joints
Battery
Four wheel alignment
Rear license plate holder
Fixed manifold oil leak.
Serpentine belt
Sun visors.
Auto dimming rear view mirror
Gas filler protector.
Backup lights
Steering column rag joint
A frame bushings
Two new serpentine belt pulleys
Fixed SYS light with the resistor mod.
New header garnish.
Rear deck trim
Removed and replaced radiator, cleaned it and straightened fins
Engine Coolant Temp sensor
Center air dam
Inspected brake pads
Right door power window switch
4 Kuhmo’s
Alternator rubber boot on electrical terminal.
Cleaned rear wheel speed sensors.
Riveted sheet metal onto door panels and used tool dip to cover all surfaces ,no more squeaks.
Headlight Delrin bushing mod
Transmission fluid and filter
Left manifold gasket
Fuel pump.
PCV valve.
Removed and cleaned the IAC.
Removed and cleaned the EGR and replaced the gasket.
Replaced the oil and oil filter.
Had emissions test.
Fuel filter
Serviced air conditioner
Fuel line clamp in engine compartment.
Both front outer tie rods.
Both rear outer tie rods
Front end alignment
Rear leaf spring bushings
Detailed exterior with all three Meguire products.
Rear inboard brake light fixture.
Installed new machined metal bushings with silver anti-seize compound in headlight horseshoe brackets
Removed and cleaned throttle body. Replaced all gaskets. Replaced all hoses too.
New throttle position sensor
U-joints
Right manifold
New water pump
New optispark
New plugs & wires
Removed and cut notches in sway bar bushings and greased them with moly grease
FSM
PKE
Two new keys.
Lug wrench
Floor mats
Driver’s headlight
Cigarette lighter.
Wiper blades.
Radiator cap.
Bilstein shocks
Lower ball joints
Battery
Serpentine belt
Sun visors.
Backup lights
A frame bushings
New header garnish.
Rear deck trim
Center air dam
4 Kuhmo’s
Fuel pump.
PCV valve.
Had emissions test.
Fuel filter
Front end alignment
U-joints
Right manifold
New water pump
New optispark
New plugs & wires
