Ken
Gone but not forgotten
Until I saw this: :eek
:J A 472 cubic inch small block Chevy with 635 horsepower!!
I would think that any SBC over 400 cubes has simonized cylinders, i.e. the Rocket 400 block that we allStallion said:So that 472 SBC probably doesn't have too much material between each cylinder. Unless it has a huge stroke and not as much bore as we would expect.
Correct - displacement is displacement, regardless of the physical size and weight of the block; assuming the same bore and stroke dimensions, compression and tuning elements, there wouldn't be any difference.Stallion said:So when people say that a big block puts out more torque than a small block, it really has nothing to do whether it's a big or small block...? For instance, this 472 is a small block, but has more displacement, so it would probably put out more torque than a 454 big block. No?
I'll still take that beautiful semi-Hemi BBC head design.JohnZ said:Correct - displacement is displacement, regardless of the physical size and weight of the block; assuming the same bore and stroke dimensions, compression and tuning elements, there wouldn't be any difference.
Here are the rest of the specs:Jack said:Wonder if they're using new first quality dart blocks or ?
Ken said:Plus, there are many more options available.
- Dart Tall Deck Iron Eagle 4Bolt HP Block with Raised Cam & Splayed Steel Billet Caps
- Callies 4340 4.250 Stroke Internally Balanced Crank
- Eagle 4340 H-Beam 6.125 Steel Rods w/ARP Bolts
- JE 10.5-1 Custom Forged Aluminum Pistons
- Air Flow Research CNC Ported 227 Aluminum Heads
- Dart CNC Ported Intake Manifold
- Ultra Street Big Dawg Polished Aluminum Valve Covers
- Offset 1.6 Ratio Aluminum Roller Rockers
- Moroso Street/Strip Oil Pan, Oil Pump & Pick Up
- Chrome Timing Cover w/ Tavia Pointer
- HP Harmonic Balancer
- Internally Balanced
- Professionally Blueprinted and Assembled
- Every Engine Dyno Tested w/Dyno Sheet Provided
I won't claim to know more, but that's largely how I understand it. The crank does this direction change thing for the rods and pistons and all of it must be strong and/or light enough to make higher revs with that longer throw of the crankshaft. The longer stroke (throw) is the simple physics a longer lever, delivering more power (torque). The space available in a SBC physically limits how long that stroke can be. We know the 350 has to be machined for the 'stroker kit' that makes them 383s.DRTH VTR said:I hope that somebody who knows more about this than I do will correct any errors here. I thought that, in general, a longer stroke (with the same displacement) will increase torque, but limit the RPM's at which the engine can operate, while a shorter stroke can decrease torque, but raise the RPM limit. Any truth to this?
