- Moderator
- #1
vetteboy86
Since you folks were so good to me last time, I thought I might ask another question. When i was having trouble with the tension spring on the secondary air valves, I just took a wire and wired them shut. For kicks I took the car for a ride, and it seemed to run alot better. I didn't have the bad bog upon acceleration. I fixed the tension spring and set it to what I think it should be. However the car is bogging again. It runs fine under idle, and easy driving. However when you get the RPM's over 3k or so it falls on it's face. When I had the secondary air valves closed, it pulled hard way past this mark. Now is it possible that whoever rebuilt my carb put the wrong size metering rods in. I was talking to a local guy and he said there is no adjustment on that linkage that controls the metering rods. He said you can either bend the linkage, or put some foil under it to act like a restriction, and effectivly make them shorter in theory.Well I just figured somebody could help me once again.
Thanks again
Craig
Thanks again
Craig
