toobroketoretire
Banned
I have always hated the miserable top post batteries with their "clamp type" cable terminals. The side post design is a big improvement but it's hard to get to the side terminals when you need a jump. A couple of years ago I thought I'd try something a little bit different. I'd put 3/8" NC brass studs into my top posts then used side post terminals with just an ordinary 3/8" NC nut to secure them.
The first picture shows 5/16" brass studs that I later changed to 3/8" studs and the "clamp on" side post terminals (picture #2) came from my local True Value. In just a matter of seconds I can connect or disconnect my battery using a 9/16" end wrench. In picture #2 you'll also see the three 1-1/4" vent holes I drilled in the rear of the battery compartment to vent the hydrogen fumes to the outside.
