Anti-Freez pouring out this tube????--'89
  • Thread starter Thread starter Magmotor
M
Magmotor
'89----Sorry for the pic but I just stuck the camera underneath and hoped for the best. This looks like an overflow tube, it's very soft plyable rubber, but it's connected to the 'starter motor'..!! Why would anti-freez be flowing out ot it?? I just had a brand new heater core put in last week. When I put the by-pass hose I had made up on, it doesn't leak there anymore. Any information would be greatly appreciated..!!!
How do I get this pic out of thumnail and larger so you can see it????
This appears to be a Chrysler product gear reduction starter. Don`t worry about the anti freeze, it`s probably some left over from the heater core replacement that dripped down on the engine. :upthumbs
Thanks for the reply Iron but wish that was the case. I start the engine and it pours out, hot......Iam constantly now having to put water back in the rad....will take it back to the place where the core was put in monday.....can't believe a bran new core is leaking....but.....when I put the by-pass hose on and it stops leaking, that proves the freez plugs are good, correct????......still like to know what that overflow tube is or whatever.....
All you have to do to see it larger is click on it and it will expand to full-size. ;)
I'm confused by this statement:
What bypass are you referring to, the throttle body coolant bypass that people sometimes perform? There is no way that coolant will be coming from the starter; that just doesn't make any sense. I have no idea what the tube is though.
Ken,
Yes, I by pass the heater core totally with a u-shape hose that connects the inlet to the outlet. The leaking then stops.... ;shrug I'm confussed myself...never seeen a tube comming out of a starter motor...it's definetly factory made and put there for a reason but.....My only guess is a freez plug is leaking and water is going over or thru the bellhousing, into the gear housing of the starter motor and out that damn little tube.....hell i don't know..
Well that's a new one on me. Hang in there, someone will come along who knows what the tube is for. :CAC
_ken
starter
I just replaced the stater on my '95 Chevy G 20 conversion van. The new (and the old) had a short rubber tube coming from the bottom front of the starter. I assumed it was to get rid of any moisture buildup or water that might get in from driving in wet conditions.
Have never seen this on any other GM vehicles I've owned.
Also, both old and new starters do not look like the typical steel shelled GM starters I'm used to seeing but rather the slightly smaller high-torque starter.
Your not looking at the drain tube for the A/C are you?
It's in the general vicinity of the starter and I'll guess if the heater core leaks, the anti-freeze may come out of it!
Hey Bro
Didn't realize you were still chasing this gremlin!!!
Lemme know if ya need a ride to the shop
Rain
RonJ
No, this is comming right out of the starter motor, as the pic shows. Labor & core has a warrenty for a year, so we'll find out tomorrow.....Thanks for everyone's help...!!!
Help
Hey Magmotor,
You helped me out before so I guess its my turn to return the favor. I'll try and stop by this afternoon on my way home from work. I'll give you a call later.
C ya
Gerald
Hrtbeat1 said:
Hey Magmotor,
C ya
Gerald
Hey my man..!! long time no see....found out what the problem is but still cruise on by if your in the neighborhood.....Blown Head Gasget...!!! only $1500 to get it fixed...sechhechss.....
OUCH -!!!! Well at least ya tracked it down.
Sounds like you need a lucky night at the casino :)
Keep me posted,
Rain
Keep me posted,
Rain
Luck is a gone delusion of the past now. While I was at Auto Air the guy's jack slipped off and went thru the floor board......the future looks bleak....
NO WAY! :eek :eek :eek :eek :eek :eek :eek
What?? How could he do such a thing? Was a child working there, who had no experience whatsoever with cars? I would be ****ed to say the least. :mad
You had better receive adequate compensation for the damages. Friggin' morons! :eyerole
Has anyone come up with an explanation for the tube that appears to be part and parcel of the starter motor? Inquiring minds want to know. :confused
_ken
The tube coming out of the starter motor is a drain tube for if you go through a puddle and water gets splashed up into the starter it won't let the starter motor to get filled up with water.
Make sense?
Mike.
