craig32
Hey all, I got a WCFB and a compatable intake for it to put on my engine when I got it back together. I had a guy rebuild the carb, but I can't seem to get any gas flowing through it. I changed the fuel pump (waste of money) and all the lines, and it still seemed like it wasn't pumping gas. Finally I took one of the carbs off of my tractor and it fired right up.
So, I know the engine runs, I just have a carb to fix. I thought maybe it was the brass element, but it was the same without it. I took off the air horn to make sure the passages were all clear, which they were. Does this sound like something in the float/needle valve area? That's my only guess at this point, anything else I should be suspicious of? Thanks as always.
Craig
PS - This is a '56 engine in a '55 Bel Air - not a Corvette - but I thought you guys would be the ones to know as the other Chevy forums aren't much help.
Craig
